Is there a plugin or script that I can use to manage videos within EE?
August 24, 2007 2:20pm
Subscribe [8]#1 / Aug 24, 2007 2:20pm
#2 / Aug 24, 2007 2:22pm
No, there isn’t. What most people do is simply set up a weblog for managing the videos with each entry being a video, and use the template to set up how to display them appropriately.
I’m also going to move this to how-to as it’s more appropriate there =)
#3 / Aug 24, 2007 2:47pm
That would be a nightmare if I had over 50 videos. I probably need to hire a developer to write a module? Can you recommend one?
You might want to have one developed since video management is starting to gain traction in membership sites.
#4 / Aug 24, 2007 2:59pm
Why would that be a nightmare? Create an entry for each video - most people have many more than 50 entries, but just put the video file name or URL to it, and do the markup in the template.
It’d take only a few minutes of setup plus creating the 50 entries, which shouldn’t take long at all really.
#5 / Aug 24, 2007 4:18pm
This uses Jeroen Wijering’s flv player which is open source and excellent. You can also make a custom playlist from any rss or xml file, or it will add all media in a directory if wanted.
I don’t use the plugin myself, I just use the player from
the players site in a template and have used it with ajax, sidebar menus etc. One can also make a separate weblog as said above and have each entry as a video… using one template with conditionals, or use the playlist. One can also use flash vars for a playlist in sidebar etc…
demo with playlist
using flashvars thumbs in sidebar
using quicktime with ajax
Using entries as videos for a video blog
Basically it isn’t difficult at all. Add the player to the page with EE tags for the video and conditionals etc…
#6 / Aug 24, 2007 8:11pm
Ok, I did not know that your weblog was the database.
#7 / Aug 24, 2007 8:42pm
Sorry to jump this post but I’m curious about the Flash player plugin. I have a weblog where I created a custom field to store the URL to some Flash video content. How can I dynamically insert this URL into the Flash Player plugin?
Thanks for any feedback.
#8 / Aug 24, 2007 8:58pm
If you were using the plugin, according to the docs for it you enter the url to the file as below. I changed it to use a custom field for the file:
{exp:flvplugin playerpath="http://www.somesite.com/players/flvplayer.swf"
playernumber="1" file="(customfieldname)" width="320"
height="240" showdigits="true"}as an example the custom field would have /videos/mynewvideo.flv
#9 / Aug 24, 2007 9:45pm
Seems simple enough. Thanks very much!
#10 / Aug 25, 2007 6:40am
There is also the quicktime plugin, if you prefer QT for your movies. Otherwise, it’s just as easy to add the movie name to a custom field and then write the embed code in a template.
{if custom_field}<object><embed src="{custom_field}" /> </object>{/if}Both methods require that all movies have the same size.
#11 / Aug 25, 2007 8:58am
Does this help too?
#12 / Dec 16, 2007 4:40pm
I used the Flv plugin and made a weblog to denote where the video was located, and what the dimensions were so you can use different sized videos.
#13 / Dec 16, 2007 5:03pm
One could also use custom fields for flv location, height, and width. 😉
#14 / Dec 17, 2007 5:01pm
me too sorry for jumping in. using youtube video embed code, we could just paste this markup in a custom field, right?
#15 / Feb 02, 2008 6:53pm
Yes, but a better way that validates:
SWFObject embed
I use, with the js link in head;
{if utube_vidid}
<div class="center">
<div id="flashcontent">
Oops! You don’t have flash installed, or JavaScript is off.
</div>
// <![CDATA[
var so = new SWFObject("http://www.youtube.com/v/{utube_vidid}", “youtube”, “400”, “326”, “8");
so.addParam("wmode", “opaque");
so.setAttribute("redirectUrl", “http://www.youtube.com/watch?v={utube_vidid}");
so.write("flashcontent");
</div>
Then I put just the video id into the custom field. Centered, valid xhtml, and easy with no “click to activate” in ie. Resize all one wants…
