Possible to "remove" index.php AND make default template group blank?
August 23, 2007 10:10am
  • #1 / Aug 23, 2007 10:10am
    ndicken
    I’ve read the docs on how to remove/hide index.php but I’m wondering how the best way - if possible - to change what now is this.
    http://www.mysite.com/index.php/template_group/template
    to appear as this:
    http://www.mysite.com/template
    Also, does this negatively affect the multiple site manager/having multiple sites in one EE installation?  I don’t have that installed now but might down the road…
    thanks,
    nate
  • #2 / Aug 23, 2007 12:16pm
    The template group really should be in there.  If you aren’t using custom 404’s and leave it out, it should default to your default template group.  But I haven’t played with it in ages, because I really don’t recommend doing it.  If you include the template group name and leave out the template name?  It will default to that group’s index page.  I do that all the time- and it would still result in the same number of segments.  Means you have to make more template groups, rather than having all of the templates in the same group- but it’s semantics at that point.
    (You can also check this wiki entry- but I just stick with EE’s default url behavior- sans index.php.  It makes life easier in the long run.
  • #3 / Aug 23, 2007 12:20pm
    ndicken
    Hi Robin, yeah good point.  I’m gonna leave it in there - it’s not as annoying as the index.php part which I have successfully taken out.  Thanks :D
    nate
  • #4 / Aug 23, 2007 12:36pm
    Heh- yea, I don’t like the index.php either.  But otherwise- a good naming convention with your template groups results in nice urls, at least from my perspective.
