Call to undefined function rss_2()
August 04, 2007 8:40pm
  • #1 / Aug 04, 2007 8:40pm
    axle_foley00
    Hello everyone,
    I’m a new EE user and am trying to install the version, 1.6.0. I followed the EE installation wizard and completed all the necessary fields, however when I get sent to the next page I get the following error:
    Fatal error: Call to undefined function rss_2() in /home/.name/username/example.com/install.php on line 2124 (I have changed the path)
    Any ideas as to why this would happen and how to fix it so the installation can continue?
    Regards.
  • #2 / Aug 04, 2007 9:49pm
    That part of the install is looking for the /themes/site_themes/rss/rss.php file. Make sure you uploaded all the files in the /themes folder.
  • #3 / Aug 04, 2007 9:53pm
    Derek Allard
    Hey Axle.  That function is part of themes/site_themes/rss/rss.php in the themes folder, so that error would indicate that it couldn’t include that file.  At any rate, it is just there for compatibility with older EE versions, and if this is a new install, it should be an easy fix (provided you are using the default EE theme).
    Could you try this for me.
    1) re-FTP up the themes folder.  Ensure it is readable by your webserver.
    1a) Try installing again and see if you get the error.  If you do…
    2) Open up install.php and comment out 2124 and 2134
    // $temp = str_replace("{stylesheet=weblog/weblog_css}", "{stylesheet=site/site_css}", rss_2());
    and
    // $temp = str_replace("{stylesheet=weblog/weblog_css}", "{stylesheet=site/site_css}", atom());
    3) Save and upload the new install file and try again.
    Let us know how it goes.
    Edit: Is there an echo in here 😉
  • #4 / Aug 04, 2007 10:00pm
    axle_foley00
    Hehe thanks for the quick responses Sue and Derek. I’ve been having loads of trouble with my FTP programming timing out, so perhaps some of the files weren’t uploaded properly (or at all). I’m currently trying to re-upload EE. Will let you know how it turns out.
  • #5 / Aug 04, 2007 10:57pm
    axle_foley00
    Derek and Sue:
    Thank you. It turns out that I did in fact need to re-upload the EE files. Once I did that everything worked.
    Thanks again.
  • #6 / Aug 05, 2007 9:51am
    Derek Allard
    We’re very glad to help… with the same advice… a few minutes apart… 😉
