Child categories
August 02, 2007 12:30pm
  • #1 / Aug 02, 2007 12:30pm
    Moonfish
    Think this has been posted before but can’t find a solid answer. All I need to do is display the child categories of a parent category.
    I was trying category= (below) but that’s obviously the wrong approach.
    <ul>
    {exp:weblog:categories weblog="default_site" category="29" show_empty="yes" style="linear"}
    <li><a href="#" title="View entries">{category_name}</a></li>
    {/exp:weblog:categories}
    </ul>
    Want to avoid extensions/plugins if possible. Any help much appreciated.
  • #2 / Aug 02, 2007 12:53pm
    You could pipe all of the categories you want to show in the category=”” parameter- so if you want to show cats 5,6,7 it would be category=“5|6|7” - but there isn’t a parameter in that tag to show the children of ‘x’- to do that, you’d need a query or a third party plugin.  Make sense?
  • #3 / Aug 02, 2007 1:04pm
    Moonfish
    Yeah that makes sense. It just means if my client adds/removes a category in future, I’ll have to update the template to add/remove the category id. No major sweat though.
    Thanks.
  • #4 / Aug 02, 2007 1:20pm
    Moonfish
    Actually, I’ve just tried that and my template is still displaying all categories. Here’s my code…
    <ul>
    {exp:weblog:categories weblog="default_site" category="39|52|27|38|53|54|43" show_empty="yes" style="linear"}
    </ul>
    What am I doing wrong?
  • #5 / Aug 02, 2007 1:24pm
    I would have sworn category was a valid parameter- but it’s just category group.  Sorry for leading you astray there.  OK- 3 options- a query, the subcategory 3rd party plugin, just hard code the links.  If you are specifying the category in a parameter anyway?  I’d just hard code the links.  It’s leaner and it’s non-dynamic anyway.  If you need it to be dynamic?  Then I’m thinking query or the subcategory plugin.
    Make sense?
  • #6 / Aug 02, 2007 1:29pm
    Moonfish
    Yes, thanks. I’ll just hard-code them in. What’s the best syntax to link to pass the subcategory id on to a subcategory template? I want to automagically display only subcategory entries on the destination page.
    Thx
  • #7 / Aug 02, 2007 6:11pm
    Ryan Irelan
    Doing a custom query to get this info isn’t very difficult and I’d bet someone has already posted the code in the forums. However, there is a subcategory plugin. Let me find the link…ah, yes, here it is. I used this sucessfully on a business site I did a couple of months back.
