Edit links missing after clicking on "update" or "publish" ?!?
July 27, 2007 5:08pm
Subscribe [0]
  • #1 / Jul 27, 2007 5:08pm
    Ozmodiar
    After editing some entries, and clicking on “update”, sometimes the “Edit this entry” link isn’t visible at the bottom of the preview page.
    Is it a known problem? If not, let me know the details you need to further investigate this issue .. thanks
  • #2 / Jul 27, 2007 5:14pm
    I’ve never seen this - is this a single entry or multi entry edit? What version and build of EE, and are you running any extensions?
  • #3 / Jul 27, 2007 5:26pm
    Ozmodiar
    - Single entry
    - ExpressionEngine 1.5.2
    - multi relationship / multi text / custom field in ee tags / template management with images
    Check the image. The bottom of the page is screwed up also.
    I checked the code in the text. The formatting is set to textile (like other essays from the same blog, which work properly ...), and all there are some “light” html tags, such as “HR”.
  • #4 / Jul 27, 2007 5:28pm
    It’s quite possible that a tag is not closed and is thusly interfering with the links.  I would first recommend updating to the latest version and build then doing some testing. You might output that entry to a template and validate to see if there are any problems you’re not spotting. I’d also recommend disabling all extensions to see if that helps.
  • #5 / Jul 27, 2007 11:51pm
    Ozmodiar
    I found what the problem was.
    The person used
    <HR WIDTH=“100%” COLOR=”#6699FF” SIZE=“2”>
    Instead of
    (the last quote sign was wrong).
    Oh well ...
  • #6 / Jul 28, 2007 12:03am
    Glad you figured it out =)
