Expession Engine shop example
July 15, 2007 7:35am
  • #1 / Jul 15, 2007 7:35am
    goliatone
    i need to build an online shop.
    Im considering to buy EE for a project, but i would like to see some examples of web shops done with it, and i would like to have more informaction on the shop module.
    regards,
    goliatone
  • #2 / Jul 15, 2007 2:43pm
    Currently the only native shopping related module is the simple commerce module, which simplifies paypal interaction and can be tied into member level.  It’s not a full blown shopping module per se.  Depending on your needs, for a full blown shopping cart, you’d probably want to integrate EE with a dedicated commerce script.  I believe zend, oscommerce and others have been used- here’s a thread discussing some of the options folks have used.  There’s also talk of a third party module in this thread.  It really depends a bit on what you need to do.
    And I’ll check with the crew to scare up some shopping site examples using EE.
  • #3 / Jul 15, 2007 3:49pm
    goliatone
    Hi Robin,
    thanxs for your fast answer. I will check the links you provided me.
    regards, goliatone
  • #4 / Jul 15, 2007 10:30pm
    stinhambo
    There is a landscape photography site that was recently posted in the ‘Site Introductions’ section of this forum.
    I believe that used the Simple Commerce function.
  • #5 / Jul 15, 2007 10:40pm
    Ryan M.
    I did www.kevinvandam.com with a combination of EE for almost the entire site, and then used Zencart for the shop area. I’m hoping eventually to use EE to do whole sites like this in the future (shopping area included), but you have to go with what is currently available!
  • #6 / Jul 16, 2007 5:00am
    goliatone
    @mdesign, cool site. How hard it is to integrate Zencart with EE?
    @stinhambo, tnxs for your reply, i will check it out.
  • #7 / Jul 16, 2007 9:34am
    Ryan M.
    It’s pretty easy to “integrate”, in my opinion. Just drop your store in a directory that isn’t in EE, make sure it’s using the same styles/stylesheets (@include works wonders for this sort of thing) and that’s just about that. Of course you don’t get to use EE’s templating system, or global variables - or anything EE while you’re in your shop area - and you have to hard code any dynamically generated links, but it at least looks like the rest of your site and users don’t notice a difference - as long as the site is working for them!
  • #8 / Jul 16, 2007 1:57pm
    goliatone
    Sounds easy enough.
    Tnxs for the reply.
