On multiple Registration Pages- is there a need?
July 03, 2007 10:19am
  • #1 / Jul 03, 2007 10:19am
    TrippAllen
    It seems that there are two separate registration forms…one for Expression Engine’s core, and one for the Forums add-on.
    My question is do I really need both?  Is there an inherent difference between registering for my core EE, and the registration for the forums?
    I’d prefer to not have a separate registration form for the Forums section.  Is it as simple as re-coding the links for Control Panel and Register within the Forum section to the main EE registration page?
    Here’s the difference:
    My preferred registration page (with altered prompts and TOS):
    http://www.unionsportsmen.org/index.php/member/register/
    The additional one that the Forums section uses (not preferred and unmodified):
    http://www.unionsportsmen.org/index.php/forums/member/register/
  • #2 / Jul 03, 2007 10:27am
    No- you can run them all through either the forum or the ‘regular’ member templates.  This site runs all member links (at least the member profile templates) through the forum member profile templates.  But you can do it the other way around- it’s largely a matter of changes links.  (Once you’ve done the regular ones, it’s also pretty easy to then do the forum ones if you like- but more maintenance running both.)  Derek talks about it a bit in this thread.
  • #3 / Jul 03, 2007 10:29am
    TrippAllen
    Whoa! Talk about fast response.  Thanks for the info.
  • #4 / Jul 03, 2007 11:16am
    Whee- you were first in line!  Glad it will work for you.
