PHP in templates, processing $_POST data
November 13, 2014 4:25pm
  • #1 / Nov 13, 2014 4:25pm
    Matthew81
    I need to process form data in a template. I have enabled PHP for the template and am using require() to pull in the processing script (which works flawlessly outside of EE). The form resides outside of EE; the action attribute points to the template.
    When I submit the form, I get the following error:
    This form has expired. Please refresh and try again.
    I disabled CSRF protection and the error persisted.
    Any ideas how to get this to work?
  • #2 / Nov 14, 2014 6:30am
    Giraffentoast
  • #3 / Nov 14, 2014 11:15am
    Matthew81
    Let me Google that for you:
    http://stackoverflow.com/questions/22488918/expression-engine-this-form-has-expired-please-refresh-and-try-again
    Thanks, but I Googled it myself, saw the same page, and can’t use the solution since I’m not willing to globally disable secure forms, and, as I said, the form is outside EE so I can’t include the XID tag. I haven’t found another proposed solution, so I came here hoping someone could recommend something. Just because Google can’t find an answer doesn’t mean there isn’t one; isn’t that what these forums are about?
  • #4 / Nov 14, 2014 11:44am
    Giraffentoast
    Sorry, that sounded way harsher than it should have. 😊
    You probably should have included all that info in your first post.
    I’ve never come across what you describe here. Why would you include a form remotely anyway…? Via iframe…? And the processing as well? Funky. Maybe there’s a cleaner way of doing this?
