whats the syntax for the select dropdown such that you can define the label and value separately. I know the PT field pack dropdown uses
name : label (http://docs.pixelandtonic.com/fieldpack/fieldtypes/dropdown/config.html)for it’s syntax but I need this to work with Channel Form and the fieldtype isnt compatible it appears
