"Undefined Index" PHP Errors after upgrade from 1.6 to 2.9
August 17, 2014 6:50pm
  • #1 / Aug 17, 2014 6:50pm
    gcylinder
    After upgrading from 1.6 to 2.9, I’m getting a set of the errors below when displaying a page containing images, one set for each image. I’m running PHP 5.4.x and it says “Fast CGI” after the 5.4.x.
    A PHP Error was encountered
    Severity: Notice
    Message: Undefined index: upload_date
    Filename: file/ft.file.php
    Line Number: 303
    Severity: Notice
    Message: Undefined index: modified_date
    Line Number: 304
    I also had Mark Huot’s File extension running in 1.6. I “resubmitted” or updated the field type for one custom field as “File” and I also ran the fix in this thread on this one custom file field, but only the part regarding the line breaks:
    https://ellislab.com/forums/viewthread/218268/
    and to see those in my template, I have to use the tag pair, or else nothing is output:
    {myFileFieldName}{url}{/myFileFieldName}
    I didn’t run the part about including the file directory, because EE is not parsing my {filedir_x} tag.
    In all other cases of file fields, where I didn’t run the fix or update/resubmit the custom field type as File, I can get output by just using the stand-alone tag, but I still get the errors:
    {myFileFieldName}
  • #2 / Aug 18, 2014 6:45pm
    gcylinder
    It’s weird: this error/warning is taking place at lines 303 and 304 of expressionengine/fieldtypes/file/ft.file.php in a function called:
    replace_tag($file_info, $params = array(), $tagdata = FALSE)
    and here’s where it chokes in that function:
    $date_vars = array(
       'upload_date' => $file_info['upload_date'],
       'modified_date' => $file_info['modified_date']
    I know next to nothing about PHP, but I reckon $file_info has a problem, so I did an echo on $file_info and it returns what looks like just a string: “Array”. The upload_date and modified_date columns in exp_files table are filled with data, so I can’t imagine what’s up.
  • #3 / Aug 19, 2014 2:54pm
    gcylinder
    I had to do two things to resolve the issue:
    Apply both steps (adding the {filedir_x} and searching replacing new lines/line breaks) of the fix from this EllisLab forum thread across the board, to all File fields not just to one File field: https://ellislab.com/forums/viewthread/218268/
    I went into the Admin for channel fields and re-submitted each custom field that was a File field type.
    Something about that exercise appears to have fixed the issue. Hope this helps someone else.
