Search Results
August 11, 2014 11:53pm
  • #1 / Aug 11, 2014 11:53pm
    garyb
    On the search results page every thing is showing up but the urls (links) are wrong. if I do it this way the links go to no search results.
    <h4 class="text-center">{exp:search:total_results} {total_results}{/exp:search:total_results} Search Results for "{exp:search:keywords}"</h4>
       <dl id="search_results">
        {exp:search:search_results}
        <dt><a href="http://{auto_path}">{title}</a></dt>
        <dd>
          {if article_excerpt != ''}
         {article_excerpt}
        </dd>
            {/exp:search:search_results}
    </dl>
    If I try it this way, the links got to the index page.
        <dt><a href="http://{if">{title}</a></dt>
       <dd>
          {article_excerpt}
         </dd>
    </dl>
    What am I doing wrong?
  • #2 / Aug 12, 2014 7:14pm
    Boyink!
    {auto_path} uses a per-channel configuration that you can change. Best bet is to set that for each channel to the most specific template that content gets used in.
  • #3 / Aug 12, 2014 7:40pm
    garyb
    I tried that and the right article comes up, but menu and footer are gone.
  • #4 / Aug 12, 2014 7:42pm
    Boyink!
    Compare the URL of the normal article view and the URL of where the search is sending you.  It should be the same.
  • #5 / Aug 12, 2014 8:13pm
    garyb
    It is the same except it has the article title append to the end of the url.
    index.php/blog/article/article_name
  • #6 / Aug 12, 2014 8:28pm
    Boyink!
    Search results need to point to a single-entry template.
    Do you have a single entry template for articles?
  • #7 / Aug 12, 2014 8:47pm
    garyb
    Yes it is a single entry template.
  • #8 / Aug 13, 2014 8:01am
    Boyink!
    Can you post example URLs of both non-search and search-results for a single article?
  • #9 / Aug 13, 2014 3:03pm
    garyb
    I ended up hard coding the menu and foot to the page. That kind of defeats the idea of templates.
    Thank For the help!
  • #10 / Aug 13, 2014 5:19pm
    Boyink!
    It isn’t necessary - you gave up..😉
  • #11 / Aug 13, 2014 6:00pm
    garyb
    Okay, lol I don’t give up. 😊
    Screen shot of menu on blog page
    page before search
    http://1900tr.com/screens/menu1.png
    http://1900tr.com/screens/footer1.png
    Search result page
    http://1900tr.com/screens/menu2.png
    http://1900tr.com/screens/footer2.png
  • #12 / Aug 14, 2014 8:05am
    Boyink!
    Do you have a ‘blog’ template group and an ‘article’ single entry template?
  • #13 / Aug 14, 2014 11:05am
    garyb
    Yes, and the search results template is in that group.
  • #14 / Aug 14, 2014 11:56am
    Boyink!
    OK, so I’d recommend reviewing EE’s native way of handling/creating URLs:
    https://ellislab.com/expressionengine/user-guide/urls/url_structure.html
    The search result URL you have - with the url-title appended on the end - is actually correct. Your single-entry template should never load on the site without a valid URL title because that’s how EE knows which entry the template needs to load.  You should have /blog/ as the index templates that shows your list of titles, then once you click through to a specific article it should be /blog/article/article-url-title.  This is how EE wants to work.
    The header and footer templates not showing at those ‘deeper’ urls is a separate issue. Can you post the template code you have in those templates?
  • #15 / Aug 14, 2014 4:56pm
    garyb
    Here are the slices of code not showing up.
    <div class="navbar navbar-default navbar-fixed-top navbar-inverse"  role="navigation">
          <div class="container">
            <div class="navbar-header">
              <button type="button" class="navbar-toggle" data-toggle="collapse" data-target=".navbar-collapse">
                <span class="sr-only">Toggle navigation</span>
                <span class="glyphicon glyphicon-arrow-down"></span>
                      MENU
              </button>
            </div>
            <div class="navbar-collapse collapse">
              <ul class="nav navbar-nav">
                <li><a href="http://{path=site_index}">Home</a></li>
                <li class="dropdown">
                  <a href="#" class="dropdown-toggle">Services <b class="caret"> </b></a>
                  <ul class="dropdown-menu" roll=menu aria-labelledby="dropdownMenu">
                    <li><a href="http://{path=site/website-design}tabindex=-1">Web Design & Development</a></li>
                    <li><a href="http://{path=site/seo}tabindex=-1">Search Engine Optimization(SEO)</a></li>
                    <li><a href="http://{path=site/content-management}tabindex=-1">Content Management Systems</a></li>
                    <li><a href="http://{path=site/ecommerce}tabindex=-1">E-Commerce</a></li>
                   <li><a href="http://{path=site/designer}tabindex=-1">What You Should Know</a></li>
                  </ul>
                </li>
                <li><a href="http://{path=site/contact}">Contact</a></li>
                <li><a href="http://{path=blog/article}">Blog</a></li>
              </ul>
            </div><!--/.nav-collapse -->
          </div>
        </div>
    Social
    <div class="social">
               {site_url}images/phone_sm.png
               <h3 class="ita mp-remove">For A Free Quote
    (941)-753-8320</h3> </div>
             </div>
             <div class="col-lg-6">
             <div class="social follow">
             <h3 class="ita mp-remove"> Follow Us</h3>
                    <a href="https://twitter.com/garyb10%22href=">{site_url}images/twitter.png</a> <a href="https://plus.google.com/+1900tr/"><a href="{site_url}images/google+.pngN9On5ijDO3iK2wJxFCWEL6d0OWYCs7aYtypography_img_src_end_      width=15% height=auto alt= ">{site_url}images/google+.pngN9On5ijDO3iK2wJxFCWEL6d0OWYCs7aYtypography_img_src_end_      width=15% height=auto alt= </a></a> <a href="http://{site_url}index.php/blog/rss%22href="> {site_url}images/rss.png</a>
                </div>
    footer
    <footer>
              <div class="row">
             <div class="col-lg-12 pro">
                   Professional Services
             </div>
          </div>
          <div class="row">
             <div class="col-lg-3">
                   About Tobacco Road Designs
                   We are located in Bradenton FL. Serving Bradenton, Sarasota, and
                   All of Florida. All of our website designs are custom designs.
                   Never from downloaded templates.
             </div>
                   Website Design
                <ul class="dlist">
                   <li>
                      User Interface Design
                   </li>
                   <li>
                      Information Architecture
                   </li>
                   <li>
                      Copy Writing & Editing
                   </li>
                   <li>
                      e-Commerce
                   </li>
                   <li>
                      Consulting
                   </li>
                </ul>
             </div>
                   Web Development
                <ul class="dlist">
                   <li>
                      Custom Applications
                   </li>
                   <li>
                      (CMS) Content Management
                   </li>
                   <li>
                      Portal Systems
                   </li>
                   <li>
                      Rich Media Development
                   </li>
                   <li>
                      (CRM) Customer Relation Management
                   </li>
                </ul>
             </div>
                   Internet Marketing
                <ul class="dlist">
                   <li>
                      SEO
                   </li>
                   <li>
                      SEM
                   </li>
                   <li>
                      Brand Identity Development
                   </li>
                   <li>
                      E-mail Campaign
                   </li>
                   <li>
                      Banner Ads & Traffic Campaigns
                   </li>
                </ul>
             </div>
          </div>
         </footer>
                <div class="row">
             <div class="col-sm-12">
                   Copyright © 1996-2014 Tobacco Road Designs All Right
                   Reserved
             </div>
          </div>
      [removed][removed]
    [removed][removed]
    [removed][removed]
    Here is an example of how I put them on the template. the removed stuff above is javascript.
    {exp:channel:entries channel="menu"}
    {menu}
