Conditional operators with string data that may include spaces and quotes
July 31, 2014 9:43am
  • #1 / Jul 31, 2014 9:43am
    biblio
    My templates have a lot of code that needs to look and see if a field is empty or not, and I’m currently trying:
    {if '{big-fat-field}' != ''"}{big-fat-field}{/if}
    and
    {if big-fat-field != ''}{big-fat-field}{/if}
    but if the “big-fat-field” has quoted test in it, the conditionals blow with a PHP error in the library/Functions.php eval process as the quotes are not getting converted.  I see in the documentation that the quotes are supposed to auto-removed, but I’m not seeing that consistently happening.  The tech note on that page suggests that “If you are testing against a word, you should enclose the word in single or double-quotes.”  Should I do this with a string?
    Alternatively, is there a plugin/feature that I could use that is closer to PHP’s empty or strlen that doesn’t care about string content?
    Thanks for any help you can provide,
    M.
  • #2 / Jul 31, 2014 10:01am
    Rob Allen
    If the field is either empty or has anything in it you could simplify the conditional:
    {if big-fat-field}{big-fat-field}{/if}
    ...so if there is any content output the value, if not do nothing
