Alright, think about it. It works on Home, it doesnt work on, say, Contact.
Why? What’s the difference between those pages?
Even though you still didn’t tell me the exact URLs, I’d guess you’re using something like http://www.example.com (Home) and http://www.example.com/contact/ (Contact).
And since you’re using RELATIVE PATHS in your image tags, no absolute paths like the one I posted above, the paths will stop working on any page located OUTSIDE your website root.
Please try what I posted up there and let me know if it worked.
