We are near completion of a new site in EE which runs on AWS using an ELB in front of a pair of m3.medium web servers whose content is being served from a pair of m1.medium database server instances. The web servers are running Apache and serving off of a replicated GlusterFS filesystem which is shared across both web servers. This is so we can at some point, should the traffic on the site warrant it, push the web servers off the file servers and make them scalable. GlusterFS is a network filesystem which can be setup much like hard drive RAID arrays depending on the number of servers being used.
The issue we have come across however is that EE’s performance on a networked filesystem is absolutely horrendous, even one locally mounted via NFS instead of via the GlusterFS protocol.
This appears to be primarily because of the function directory_map() located in:
system/codeigniter/system/helpers/directory_helper.phpFrom the debugging output I’ve dumped into this section of code, on our client’s front page alone, directory_map() is called 2,227 times, and ends up calling is_dir() 5,570 times. The best time which I’ve seen the front page respond is 10.74s, but averages more often at roughly 15.4s.
For comparison, the current site for this company runs off of an ancient custom CMS we are trying to get rid of, but comparatively it runs rings around EE in the same setup using a slightly less powerful set of m1.medium web servers. Response times in this custom CMS are typically 150ms-600ms depending on server load.
We have several other site which also use EE, and through creative uses of the various caching systems available, have brought this time down to as little as 2s, but that is still far higher than desired for a server with little to no traffic.
I’ve already rewritten the function to use scandir instead of readdir, which over the course of a page provides up to 0.5s of improvement but clearly this still isn’t going to make the page load acceptable from 12.5s to 12s. Given the number of redundant times different parts of EE use directory_map while loading a page, I am considering running a simple cron job to store all of this information in a file once per minute (or more), and rewriting directory_map() to read and parse that file to pass back the same information.
Are there better options than this?
[UPDATE: 20140704 17:17:34pm] - Forgot to attach screenshot
