Hi
I have received some code to add a “widget” for booking a hotel room. The code is two part:
1. html code
<div 150px; border: 1px solid #ccc; background-color: #fff; padding: 15px; margin: 30px;"><div id="searchContainer" class="cb-widget"></div></div>2. Some javascript
[removed]var easyAccessHotelsWidgetScriptLoaded = false;function easyAccessHotelsInitJQuery() {if (typeof (easyAccessHotelsOwnJQuery) == "undefined") {if (!easyAccessHotelsWidgetScriptLoaded) {easyAccessHotelsWidgetScriptLoaded = true;[removed]("<scr + "ipt type=\"text/javascript\" src=\"//eaonline.citybreak.com/Content/widget/script/WidgetScripts.min.js\"></scr" + "ipt>");}setTimeout("easyAccessHotelsInitJQuery()", 50);}else {var baseUrl = "//eaonline.citybreak.com/widget/GetWidgetSearchFormMultipleRooms";(function ($) {$.getJSON(baseUrl + "?channelId=f585a68f-c601-4f40-8490-8e086a5d873d&openOpti; (json) {$("#searchContainer").html(json.Widget);});})(easyAccessHotelsOwnJQuery);}}easyAccessHotelsInitJQuery();[removed]But if I add that to the page, I get this error:
A PHP Error was encountered
Severity: User Warning
Message: Invalid EE Conditional Variable: {if (typeof (easyAccessHotelsOwnJQuery) == "undefined") {if (!easyAccessHotelsWidgetScriptLoaded) {easyAccessHotelsWidgetScriptLoaded = true;[removed]("");}
Filename: libraries/Functions.php
Line Number: 2640
The page use embedded templates for the html head and the footer. If I create a straight up, simple html page with no embedded templates, the code works with no errors.
Anyone know how to solve this?
Best regards, Magnus
*UPDATE*
Looks like it was an error in the javascipt:
- Only two == characters (changed that to three: === )
- One parantes to many at the end of the file
