Channel Form clears relationships on submit
May 20, 2014 11:14am
  • #1 / May 20, 2014 11:14am
    fitzage
    I’m including the entirety of my test page. I was initially having this problem with Zoo Visitor, but I pulled it out to test the underlying capability of Channel Form, and discovered that I have the same problem here.
    In EE 2.8.1, this code properly displays the options for the related field. But when the form is submitted, the field gets cleared. If I update the related entry in the back end, this front-end form will display the correct item in the dropdown until the form is submitted, and then it wipes the relationship.
    Any ideas? Am I doing something wrong? I got this code directly from the documentation.
    {embed="main/header"}
    {exp:channel:form channel="zoo_visitor" return="/main/success" entry_id="1"}
     <select name="expertise">
         {options:expertise}
             <option value="{option_value}"{selected}>{option_name}</option>
         {/options:expertise}
     </select>
     <input type="submit" name="submit" value="Submit">
    {/exp:channel:form}
    {embed="main/footer"}
