Bootstrap Carousel & EE entries via Modulus
May 06, 2014 3:54pm
  • #1 / May 06, 2014 3:54pm
    iDzine
    Actually not an issue, but just some code I wanted to share to hopefully help others.
    I was looking for a way to implement multiple EE posts into a Bootstrap Carousel, but kept failing with the next ‘active item’ class not being properly assigned.
    Looked into the {Switch} operator, but also not getting the desired result.
    Then came out on a post suggesting a plugin called SurgerEE which is pretty cool, but then I discovered something similiar is built in as from EE 2.7.1 called the modulus % operator.
    My code:
    <div id="carousel-example-generic" class="carousel slide" data-ride="carousel">
      <div class="carousel-inner">
        <div class="active item">
          {exp:channel:entries channel="products" dynamic="on"}
            <div class="col-md-4">
              {product_thumbnail}
                <div class="carousel-caption">
           <h4>{product_price}</h4>
    <p>     </div><br />
        </div><br />
            {if count % 3 == 0 AND count <> total_results }  <!-- Every 3rd post will close the banner displayed and create an new div with the class item --><br />
              </div> <br />
              <div class="item"><br />
            {if:elseif count == total_results} <!-- If end of posts is reached, just close the item class--><br />
              </div><br />
            {/if}                 <br />
       {/exp:channel:entries}<br />
      </div><br />
      <a href="#carousel-example-generic%22class=%22left" class="left carousel-control">_   <span class="glyphicon glyphicon-chevron-left"></span>_  </a><br />
      <a href="#carousel-example-generic%22class=%22right" class="right carousel-control">_   <span class="glyphicon glyphicon-chevron-right"></span>_  </a><br />
     </div>
    This will result into a carousel with in this case 3 different entries from my ‘products’ channel and will create the next item class div with other entries until every post in the channel is processed.
    Cheers!
