Upload an Avatar in CP not working
March 25, 2014 12:47pm
  • #1 / Mar 25, 2014 12:47pm
    design132
    For some reason the “browse” button is missing.  Why is this happening in version 2.7.3   Can anyone else reproduce this?
  • #2 / Mar 25, 2014 1:54pm
    Rob Allen
    Never seen that before.
    A few things to check:
    1. Check in the source code for the page, do you see the select field with the list of avatars and/or the file upload field?
    2. Make sure the /images/avatars folder is writable
    3. Under Member preferences make sure settings are ok and path’s URL’s are correct
    4. Make sure you uploaded images to /images/avatars
  • #3 / Mar 25, 2014 2:19pm
    design132
    It’s super weird because we use the avatars on the front end with solspace’s user module so they are definitely enabled, in fact on this particular screenshot there is an avatar that was placed via the front end that appears so all paths are writable.  I checked the source code and I find this interesting that the upload field is there but is hidden in the CP.  Is there a setting for this that I just never knew about?
    <h3>Edit Avatar</h3>
    <p> <form acti method="post"  enctype="multipart/form-data"></p>
    <p><input type="hidden" name="id" value="603" /></p>
    <p><br />
     <br />
      <span>Current Avatar</span><br />
      <a href="http://mysite.com/images/avatars/uploads/avatar_603.jpg">http://mysite.com/images/avatars/uploads/avatar_603.jpg</a> </p>
    <p> <br />
      <span>Browse our Avatar Library</span><br />
         <a href="http://index.php?S=7648d7954cfc39225058d178cccba80f&D=cp&C=myaccount&M=browse_avatars&folder=default_set&id=603">Default Set</a><br />
       </p>
    <p>  <br />
      <label for="userfile">Upload an Avatar</label>  <input type="file" name="userfile" value="" userfile="url" class="field"  />  <br >Allowed Image Types: gif, jpg, png  <br />
    Max Image Size: 5000 X 5000 - 5000KB </p>
    <p> <input type="submit" name="upload_avatar" value="Upload Avatar" class="submit" /></p></p>
    <p>  <input type="submit" name="remove" value="Remove Avatar" class="submit" /></p><br />
     <br />
     <br />
     </form
  • #4 / Mar 25, 2014 3:03pm
    Rob Allen
    Hmmm strange for sure. I’m wondering if the actual pixel size of the image is affecting the display?
  • #5 / Mar 25, 2014 3:22pm
    design132
    Damnit you are right.  I’m very sorry, I had no idea because it doesn’t look broken and the first three or four people;s images are so damn big but when I went to one that wasn’t, it appeared.  Thank you!!
  • #6 / Mar 25, 2014 3:29pm
    Rob Allen
    No worries! I did think those images were a bit large to fit on the screen:)
