No results tag does not work when using conditionals in MSM sites
February 27, 2014 9:12pm
  • #1 / Feb 27, 2014 9:12pm
    gbederson
    Is there a way to get the no_results tag to work when using conditionals and msm? The problem is that I cannot use the search: parameter to limit the results, because it seems the Multiple Site Manager does not recognize “search:”. MSM does work with conditionals, though, so I am forced to use them. But no_results does not recognize conditionals.
    The following code does not work, because search is not functional with the “site=” tag.
    <pre><code>{exp:channel:entries site="implications" channel="place" search:url_title="{embed:place}”}
    {if url_title == "{embed:place}”}
    {title}
    {if no_results}No successes yet.{/if}
    {/exp:channel:entries}</code></pre>
    The following code returns the correct results for “{title}”, but no_results is incorrect because it is not limited by the conditional.
    {exp:channel:entries site="implications" channel="place"}
    {if url_title == "{embed:place}"}
    {title}
    How can I show no_results when using MSM and limiting the results with search: or conditional?
    Any help would be appreciated!
    Geoff
  • #2 / Mar 07, 2014 7:06am
    ahmad saad
    as I think there is no problem with MSM , the problem is in your code itself:
    first: url_title not work with search: u must use url_title param http://ellislab.com/expressionengine/user-guide/add-ons/channel/channel_entries.html#url-title
    second: when u need to use no_results condition , there is no need to put it in any tag, just put it in the first line after {channel:entries} loop and it will do the trick.
    so your code will be:
    {exp:channel:entries site="implications" channel="place" url_title="{embed:place}"}
    {title}
