Prefixing custom fields
February 26, 2014 5:00am
  • #1 / Feb 26, 2014 5:00am
    kenny2
    Can the new Template Layouts be used to prefix custom fields?
    I have 2 product channels that have virtually identical fields, but because of the way CartThrob tracks inventory I cannot share a field group over these two channels. This leads to some bloat in my templates that I would like to cut down.
    I was about to look in to the technique that uses Stash..
    http://expressionengine.stackexchange.com/questions/12261/set-custom-field-prefix-with-stash
    .. but if Template Layouts can be used it would make sense to use what is built in.
  • #2 / Feb 28, 2014 1:30pm
    Rob Allen
    I haven’t seen the docs for Page layouts yet so don’t know.
    Have you looked into Preload Text Replacements for prefixes? http://ellislab.com/expressionengine/user-guide/templates/globals/preload_replacement.html
  • #3 / Mar 10, 2014 6:42am
    kenny2
    Hi Rob,
    this gives an idea of what I am trying to do, my problem is getting the prefix in the field=”” parameter. I don’t believe preload replace can be used for this?
    What I have..
    {exp:tag:related_entries channel="ch1|ch2|ch3|ch4"}
     {if channel_short_name == "ch1"}
      {exp:channel_images:images entry_id="{entry_id}" field="ch1_gallery" cover_only="yes"}
      <a href="http://{path={channel_short_name}/{url_title}}">{title}</a>
      {/exp:channel_images:images}
     {if channel_short_name == "ch2"}
      {exp:channel_images:images entry_id="{entry_id}" field="ch2_gallery" cover_only="yes"}
     {if channel_short_name == "ch3"}
      {exp:channel_images:images entry_id="{entry_id}" field="ch3_gallery" cover_only="yes"}
     {if channel_short_name == "ch4"}
      {exp:channel_images:images entry_id="{entry_id}" field="ch4_gallery" cover_only="yes"}
    {/exp:tag:related_entries}
    What would be better..
      {exp:channel_images:images entry_id="{entry_id}" field="{channel_short_name}_gallery" cover_only="yes"}
  • #4 / Mar 10, 2014 8:53am
    ahmad saad
    try to use parse=“inward” in ur code:
    {exp:tag:related_entries channel="ch1|ch2|ch3|ch4" parse="inward"}
    if this don’t work u can always use embed template.
    Regard’s.
  • #5 / Mar 10, 2014 10:15am
    kenny2
    Great, Parse Inwards works for that scenario, but further down in my code I also have:
        {ch1_stub}
        {ch2_stub}
        {ch3_stub}
      {ch4_stub}
    I am pretty sure {{channel_short_name}_stub} will not work
  • #6 / Mar 10, 2014 10:47am
    ahmad saad
    the general way is to use your code or use embed template to avoid {if} statement.
    anyway from some time I find this addons http://devot-ee.com/add-ons/entry-data
    and I add get custom field future to it.
    I upload my version in this post , when u use this plugin u can write ur code as following:
       {exp:entry_data:custom_field url_title="{url_title}" field_name="{{channel_short_name}_stub}" channel="{channel_short_name}"}
  • #7 / Apr 03, 2014 11:44am
    kenny2
    Thanks Ahmad, I have tried your plugin but using your example I am still getting a problem passing the field name:
    Gives me this in the debugger:
    {exp:entry_data:custom_field url_title="my-title" field_name="{ch1_stub}" channel="ch1"}
  • #8 / Apr 03, 2014 1:25pm
    ahmad saad
    Hi Kenny2,
    yes this is my fault just remove the parentheses.
       {exp:entry_data:custom_field url_title="{url_title}" field_name="{channel_short_name}_stub" channel="{channel_short_name}"}
    Regard’s.
  • #9 / Apr 04, 2014 7:06am
    kenny2
    Awesome, that works really well and also inside relationships, but I am struggling to apply it to a Grid field and a CE Image field. Is this stretching what the plugin can do? (The XX is where I want the prefixed channel short name to be).
    {exp:channel:entries channel="ch1" entry_id="10"}
     {relationship_field}
      <div>
       {relationship_field:XX_main_image limit="1"}
        {exp:ce_img:single src="{relationship_field:XX_main_image:key_image}" title="{relationship_field:XX_main_image:description}"}
       {/relationship_field:XX_main_image}
       {exp:entry_data:custom_field url_title="{relationship_field:url_title}" field_name="{relationship_field:channel_short_name}_stub" channel="{relationship_field:channel_short_name}"}
      </div>
     {/relationship_field}
  • #10 / Apr 04, 2014 8:36am
    ahmad saad
    Hi ,
    I don’t think this can be done , this plugin is return a single value fields.
    maybe you use embed variable here.
    Regard’s.
