upgrade from 1.7 to 2.7 failing at step 'archiving templates'
November 15, 2013 4:49pm
  • #1 / Nov 15, 2013 4:49pm
    ABDC
    I am trying to upgrade a site from 1.7 to 2.7. Because it is a complex multisite installation, has a lot of extensions and uses the image gallery module a lot, I decided to copy the complete installation to a subdirectory and upgrade that first. I figured I needed to do too many template and site changes to be able to upgrade the live site immediately. I had the copy running good on a subdomain, then I tried to upgrade. Now the upgraded stops at the following error:
    An Error Was Encountered
    There was an error moving your existing template files to an archive folder. Please manually move any folders in the form system/expressionengine/templates/<site_short_name>/ to a backup location and then Resume the Update.
    Nothing will make it continue. I can see it has something to do with the multisite module? But what and how do I get further with the upgrade now?
    Many thanks in advance for any insights / pointers…
  • #2 / Nov 16, 2013 5:41pm
    ABDC
    Since this is the weekend and the site is not active then I decided to try my luck on the original root installed site. This worked! So the problem probably arose from moving the install.
    Now I encountered the corrupted site preferences in database error outlined in several threads, for example here: http://ellislab.com/forums/viewthread/222948/P15
    I solved it by converting the contents of the exp_sites preferences table to 64base, so almost the instructions as provided but slightly different:
    1) Copy the contents of the site_system_preferences column from the exp_sites table.
    2) Paste here [http://blog.tanist.co.uk/files/unserialize/index.php], do NOT check “base64 decode”, and click “Unserialize!”
    3) Scroll down to the bottom of the resulting page to re-serialize it, DO check “base64 encode”, and click “Re-serialize!”
    4) Copy the results, and paste them into the field they came from in the exp_sites table.
    5) repeat for all preferences columns
    6) in cases of MSM: repeat for all sites.
    The ‘site_pages’ column uses a slightly other format than the others which the tanist tool would not reserialize. I used http://www.base64encode.org to reserialize these. I do not yet know if this was successful as I have not managed to enter the CP, but the installer has moved on to another error.
    I now have the following error:
    A Database Error Occurred
    Error Number: 1054
    Unknown column ‘has_publish_fields’ in ‘field list’
    UPDATE `exp_modules` SET `has_publish_fields` = ‘y’ WHERE `module_name` = ‘Pages’
    Filename: <serverpath>/expressionengine/modules/pages/upd.pages.php
    Line Number: 147
    So I am investigating that now.
  • #3 / Nov 17, 2013 5:17pm
    ABDC
    Searching for the error “Unknown column ‘has_publish_fields’ in ‘field list’ UPDATE `exp_modules` SET `has_publish_fields` = ‘y’ WHERE `module_name` = ‘Pages’” does not throw up any help from the EE forums. Checking the indicated PHP file I see:
    if (version_compare($current, '2.1', '<'))
       ee()->db->where('module_name', 'Pages');
       ee()->db->update('modules', array('has_publish_fields' => 'y'));
      if (version_compare($current, '2.2', '<'))
       $this->_do_22_update();
    Where does the installer get his version nr from? If I check the config it says version 271; why would this file try to update anyway?
    I actually do not use the pages module; just have it installed. Could I just comment out this function? Or somehow uninstall the pages module without access to the control-panel?
    I feel like I am now in update limbo with only access to the database via phpmyadmin and access to the actual installed files, but not to the control panel of front-end of the website.
