After upgrading to EE2.7.2 and upgrading Multiple Site Manager I’m unable to access the control panel for my default site via the default site’s control panel.
When I log in to control panel from http://www.defualt-site.com/admin.php I automatically am redirected to site2’s control panel instead. However, the default site is visible from the site menu on the top right when I get redirected here. Clicking on the link for the default site doesn’t do anything, it just bring’s me back to site 2’s control panel.
The strange thing is that when I log into control panel at site 2 (http://www.site2.com/admin.php) I’m able to access both sites via the site menu and everything works as expected.
Everything else on the site seems to be functioning normally, folder structure and the paths used in the index.php and admin.php files are the same that I was using successfully prior to upgrading.
On other thing that may have some bearing is that I have my system folder setup above the web root folder.
Any ideas?
