Currently I have site running on Magento 1.4.4 but it required a lot of customization by adding extensions and customizing them which overall made Magento installation a big mess. Actually I have hit a wall where I can’t upgrade extensions because of those customizations, some functionality requests are not possible to achieve within Magento (developers community is pretty weak), etc. After that owner of that store decided to go for something custom.
I have done two custom sites based on CI and EE2 but both are not e-commerce dedicated.
After some initial research I have found that most of them was done using EE2 with addons like Foxee (http://www.hccdevelopment.com/Web-Based-Software/Product/foxee/), BrillaintRetail (http://devot-ee.com/add-ons/brilliantretail), Expresso (https://exp-resso.com/), CartThorb (http://cartthrob.com/), GoCart (http://gocartdv.com/) or just using EE2 and Simple Commerce module.
I’m looking to have extension well documented and easy to customize without any overhead like Magento has.
Any suggestions, pros and cons?
