Dynamic Menu list per channel entry
October 23, 2013 4:25pm
  • #1 / Oct 23, 2013 4:25pm
    prhey404
    I have 5 channels with different custom fields. Each channel entry displays on its own page. On every page, there is a navigation with links to other entries from that channel only. When a new channel entry is created, a new link is generated in the navigation. But I need the navigation and the channel entry to always display on the SAME PAGE.
    Here it is working manually - http://fullcirclecreatives.com/clients/sweetmoments/cupcakes/vanilla.html
    On the left hand navigation you click an item and a new page displays, along with an “active” link style.
    I have it half working dynamically. Here is the navigation working correctly - http://sweetmomentsinc.com/index.php?/cupcakes/cupcake_test_template
    But when you click on a menu item, only the link for that entry is displayed and the rest of the links disappear. If I can get it to work like my manual website that would be awesome!
    Left navigation code:
    <ul>
    {exp:channel:entries channel="cupcakes" sort="asc" disable="member_data|pagination|categories"}
    <li><a href="http://{url_title_path=" title="{title}">{title}</a></li>
    </ul>
    Channel entry display code:
    {exp:channel:entries channel="cupcakes" limit="1"}
    <div class="flavors">
                <h3>{title}</h3>
    <p>            {cupcake_description}</p>
    <p></div><br />
  • #2 / Oct 23, 2013 8:02pm
    prhey404
    I figured it out, it was really simple. All I had to do was add dynamic=“no” to my dynamic navigation channel entry code, and embed the dynamic menu into the page where the entry is displayed.
    {exp:channel:entries channel="cupcakes" sort="asc" dynamic="no" disable="member_data|pagination|categories"}
    It sounds kind of ironic because I want a dynamic menu, but then I have to make the menu itself not be dynamic when I embed it in the page. Now all I have to do is figure out how to add my active css style to the navigation according to which entry is clicked.
