Hi, I’m having a weird problem with entry form layouts. I’m finding that no matter what I try I can’t get the entry layout to save properly. After saving, when I return to the Channel Entry page the field positions do not display in the positions I saved them in. I’ve also found that I cannot drag some custom fields into new tabs, the ‘eye’ icon does not show against some fields in the toolbar and the tab labels save in lowercase with underscores.
Has anyone else experienced this? And know of a fix?
EE version 2.7.1, all addon field types are up-to-date versions
EDIT:
I’ve just installed EE 2.7.1 locally, without any addons, created one custom field and one channel. The same problem occurs. Is this a bug? If so where to I go next?
EDIT 2:
Scratch that I’ve updated to 2.7.2 and it seems to be behaving itself at the moment.
