Please Help - Invalid after submit
October 05, 2013 5:15pm
  • #1 / Oct 05, 2013 5:15pm
    c.nico
    I could really use some help on this.
    Not sure what I’ve missed, but I keep getting weird messages/errors while working in the control panel. I can’t submit/publish any entries without getting this message:
    {"message_failure":"The action you have requested is invalid."}
    I’m also getting strange messages from other areas of the control panel. All of these alerts/messages appear on an otherwise completely blank white page.
    {"message_success":"Field Group Created: ..."}
    "Logged out"
    {"base":"admin.php?S=a085… D=cp","messageType":"success","message":"You are now logged back in!"}
    Please help if you can. I think *think* I’ve double checked everything and I simply can not figure out what the heck is happening.
    I’ve also searched the forums and the web for an answer, but I haven’t found anything yet.
    Thanks in advance!
    c
  • #2 / Oct 05, 2013 5:33pm
    c.nico
    Almost any button “Submit”, “Update”, that I press inside of the control panel, returns this message -
  • #3 / Oct 05, 2013 7:09pm
    c.nico
    To add to the confusion, if I remove the file upload field from the channel fields group, I can submit an entry, but I get this message on a completely blank page.
    {"message_success":"New Entry Submitted"}
  • #4 / Oct 05, 2013 7:26pm
    c.nico
    Problem Solved!
    For future EE’rs. Solved this problem by changing the PHP version on my server from 5.3.27 FastCGI to 5.3.27 CGI Stable.
    Whew.
  • #5 / Jul 04, 2014 11:31pm
    Problem Solved!
    Whew.
    You really saved my life with this one! For anyone who ever sees messages after pretty much any submit that look like this > {"messageType":"foo"} - you need to make sure that you’re not using 5.3.27 FastCGI on your server. The site I’m building is on Mediatemple and this was the default when I created the domain. You must use 5.3.27 CGI Stable.
    Again, many thanks for this!
