I am trying to publish my book on my website. I am using ‘categories’, which correspond to the title of each chapter entry (the result is similar to Acrobat Reader, where the contents are shown in the sidebar). It works okay, however, as I wish to allow the reader to make comments on each chapter, I run into the problem that the comments form will not show.
The book.channel preferences is set to allow comments.
When I click on the sidebar chapter ‘becoming-a-success’ , the URL shown is
http://localhost/HTGMC/index.php/book/section/category/becoming-a-success
where ‘book’ is the channel and ‘section’ is the template.
The code in the section template is given below…
<div id="main">
{exp:channel:category_heading channel="book"}
<h2>{category_name}</h2>
<p> {/exp:channel:category_heading}<br />
<br />
{exp:channel:entries channel="book" limit=1}<br />
{body}<br />
<a href="#">{comment_total} comments</a></p>
<p> {/exp:channel:entries}<br />
<br />
<h3 id="leave-a-comment">Leave a comment. <em>*Required</em></h3><br />
{exp:comment:form channel="book" form_class="comment-form"}<br />
<ul><br />
<li class="comment-name"><br />
<div class="label"><br />
<label for="form-name">Your Name*</label><br />
</div><!-- /end .label --><br />
<div class="input"><br />
<input id="form-name" name="name" type="text" size="35" value="{name}" /><br />
</div><!-- /end .input --><br />
</li><!-- /end .comment-name --><br />
<br />
<li class="comment-email"><br />
<label for="form-email">Email*</label><br />
<input id="form-email" name="email" type="text" size="35" value="{email}"/><br />
</li><!-- /end .comment-email --><br />
<br />
<li class="comment-website"><br />
<label for="form-website">Website</label><br />
<input id="form-website" name="url" type="text" size="35" value="{url}" /><br />
</li><!-- /end .comment-website --><br />
<br />
<li class="comment-content"><br />
<label for="form-content">Comment</label><br />
</div><br />
<textarea id="form-content" name="comment" cols="40" rows="10" />{comment}</textarea><br />
</div><br />
</li></p>
<p> </ul><br />
<input id="comment-submit" type="submit" value="Submit Comment" /><br />
{/exp:comment:form}<!-- /end form.comment-form --></p>
<p> <br />
<br />
<br />
<br />
<hr><br />
<br />
</div><!--end main--><br />
<br />
<div id="nav"><br />
{exp:channel:categories channel="book" style="nested" class="categories"}<br />
<a href="http://{path=book/section}">{category_name}</a><br />
{/exp:channel:categories}<br />
</div>
I suspect that the reason the contact form does not show, is because, it assumes the page can show multiple entries, rather than a single entry. If this is the case, is there a workaround, or a better way, rather than using categories?
