entry mapper and other animals (channels)
August 05, 2013 8:43pm
  • #1 / Aug 05, 2013 8:43pm
    danc
    I have just purchased the new entry mapper from devdemon. I am posting here because as a newbie I feel this is much more an error in my understand of EE tags than an issue with entry mapper:
    <html lang="en">
    <head>
      <meta charset="utf-8" />
      <title>jQuery UI Dialog - Animation</title>
      <link rel="stylesheet" href="http://code.jquery.com/ui/1.10.3/themes/smoothness/jquery-ui.css" />
      [removed][removed]
      [removed][removed]
      <style>
      input:focus,
      select:focus,
      textarea:focus,
      button:focus {
          outline: none;
      body {
       color: #333
      #fixedContainer
        position: fixed;
        width: 960px;
        height: 640px;
        left: 0%;
        top: 0%;
        margin-left: -300px; /*half the width*/
      div#links a span {
       display: none;}
      div#links a:hover span {display: block;
         position: fixed; top: 250px; left: 250; width: 300px;
         padding: 5px; margin: 10px; z-index: 100;
         color: #AAA; background: black;
         font: 10px Verdana, sans-serif; text-align: left;}
     </style>
    </head>
    <body>
    {exp:channel:entries channel="staff" limit="1"}
     {exp:entry_mapper:map map_name="map" }
       <div >
           {mapper:image_url}
           {mapper:entries}
        {exp:channel_images:images entry_id="{entry_id}"}
           <span class="entry">
            <div id="links"><a href="#">{mapper:entry_id}<span>{image:url:small}</br>Department: {employee_department}</br></br>Job Title: {employee_job_title}</br></br>ext: {employee_extension} | cell: {employee_cell_phone}</br></br>email: {employee_email}</span></a></div>
           </span>
        {/exp:channel_images:images}
        </div>
          </div>
       {/mapper:entries}
     {/exp:entry_mapper:map}
    </body>
    </html>
    The above is my html/EE code. The Template is pulling from the Staff channel and displaying the mapper ID tag on the map (image)
    Hovering over the {mapper:entry_id} is supposed to expose the span containing staff info, photo etc.
    There are currently two entries in the Channel and the map indicates the 2 different mapper:entry_id’s in the correct places, however hovering over the mapper:entry_id brings up the same Entry from the Staff channels for both.
    If I remove the Limit=“1” from {exp:channel:entries channel="staff" limit="1"} the I get Two Maps one after the other the second map showing the same mapper:entry_id’s both with hovering brings up the second Entry from the Staff channels for both.
    I hope this is clear and someone can help
    Many thanks in advance.
  • #2 / Aug 05, 2013 9:28pm
    danc
    Solved. Coffee and some fresh air:
    <body>
    <div id="fixedContainer">
     {exp:entry_mapper:map map_name="4th_floor"}
     <div >
         {mapper:image_url}
      {exp:entry_mapper:entries map_name="4th_floor"}
              <div id="links"><a href="#">[0]<span>{image:url:small}</br>Department: {employee_department}</br></br>Job Title: {employee_job_title}</br></br>ext: {employee_extension} | cell: {employee_cell_phone}</br></br>email: {employee_email}</span></a></div>
              <!-- You can use all {exp:channel:entries} variables -->
       </span>
      {/exp:entry_mapper:entries}
     </div>
    </div>
