Autosave with Expresso Fieldtype
June 20, 2013 5:21pm
  • #1 / Jun 20, 2013 5:21pm
    HoohaaDesign
    I am using EE 2.6.0 with Expresso 3.1.3 and the autosave function doesn’t work.
    If any other field is modified the change will be saved and the ‘Autosaved Entries’ button will appear.
    If the change is made inside the Expresso Fieldtype the ‘Autosaved Entries’ button doesn’t appear at all and the change isn’t autosaved.
    From what I’ve read Expresso should support autosave.
    Has anyone else experienced similar problems any advice would be appreciated.
    Also can anyone recommend another WYISWYG that is compatible with autosave.
    Thanks a lot
  • #2 / Jun 23, 2013 11:12am
    travisb
    You might get a solution in this case in the Expresso forum: http://devot-ee.com/add-ons/support/expresso/viewforum/1488
