Creating a form
May 30, 2013 2:16pm
  • #1 / May 30, 2013 2:16pm
    Mohammed Zayan
    Hi there,
    I want to create a form which contain textarea & seletc option like the photo in attachment
    How can I do it?
  • #2 / May 30, 2013 9:54pm
    Bhashkar Yadav
    Hi Mohammed,
    I think, it is the registration page with some member custom fields. You can use Freemember (https://exp-resso.com/freemember) module for the registration.
    Hope, it would help you.
  • #3 / May 31, 2013 4:01am
    Mohammed Zayan
    Hi Bhashkar, Thank you for your replay.
    The photo is just an example, I don’t have a registration form in the site.
    I have 3 forms in the site and each form has different fields.
    I use 3 add-ons but it can’t give me what I want so I want to build it myself.
  • #4 / May 31, 2013 1:35pm
    Bhashkar Yadav
    Hi Mohammed,
    Did you try FreeForm (http://www.solspace.com/software/detail/freeform/). Its having free version also.
  • #5 / May 31, 2013 3:00pm
    Mohammed Zayan
    Yes I try it.
    the free version doesn’t have select option field type
  • #6 / Jun 01, 2013 5:45am
    Mohammed Zayan
    I want to make this form.
    Someone help me, please.
    This is the first site I make by EE
  • #7 / Jun 02, 2013 12:12am
    Bhashkar Yadav
    Hi Mohammed,
    Yes, the Freeform Free version doesn’t have select option field type but you can create a text field for it and on the front end put the same name for drop down as drop down are single select so its value will be saved within text field of FreeForm.
    If you would like you can use Safecraker also in which form submission data will be saved into channel entries. In this approach you can easily create drop down options as channel’s custom field and populate it.
  • #8 / Jun 02, 2013 2:05am
    Mohammed Zayan
    Thank you Bhashkar.
    I use proform and it do what I want.
    Thank you.
