It seems that on each upgrade there is someting that goes wrong. After update to latest version I have this problem.
Suddenly, 24-36 hours after upgrade accessories just uninstalled without any action from me, and I am only super admin. How is that even possible? Could a problem be in one error that showed only once? It is not a problem to install them again (just click install) but how is that possible? health check worked normally and then just stopped, now css is broken on that accessory.
also CP is full of errors, i wanted to install devot-ee monitor, and got a lot of errors, went back, tried few minutes later, then no errors, now it works. I tried to changed localisation to Croatia (how come default is Serbia for me?) and got several errors, then went to my member profile that is set as master account for localisation, there I changed localisation to Croatian, then went back to admin-> localisation, now I can change without a problem/error, BUT it seems that all entries that publish are 60 minutes off set date. What is set to publish in 9AM, is visible at 8AM and so on ...
