parent orderby problem in 2.6
April 30, 2013 5:28pm
Subscribe [6]
  • #1 / Apr 30, 2013 5:28pm
    truffl
    The 2.6 upgrade magically created the parents statement below.
        {parents channel="question" orderby="question_order|entry_date"}
    It throws the PHP error that you see below.
        Message: Parameter 1 to array_multisort() expected to be a reference, value given
        Filename: relationship_parser/Parser.php
        Line Number: 583
    The statement on that line does not make sense to me as it calls the array_multisort using call_user_func_array rather than directly calling it. I commented out the line and replaced it with the direct call as indicated below and it seems to work.
      //call_user_func_array(‘array_multisort’, $sort_parameters);
      array_multisort($sort_parameters);
    I am running PHP v5.3.3.
    Is this the correct fix for this problem?
  • #2 / May 13, 2013 5:25pm
    amityweb
    Where is this file please?
    I am surprised by the lack of supported fix to this, its such a visible error.
  • #3 / May 13, 2013 5:27pm
    amityweb
    I found it…
    /system/expressionengine/libraries/relationship_parser/Parser.php
  • #4 / May 16, 2013 12:08pm
    wondermade
    FWIW We had the same problem and the same fix worked.
    Spoke too soon.
    No matter how I adjust the settings I can’t get it to sort.
    {parents field="media-unit" orderby="entry_date" sort="desc"}
     <tr class="{switch="|gray-row"}">
      <td class="series-episode"><a href="/media/{parents:url_title}">{exp:trunchtml chars="45"}{parents:title}{/exp:trunchtml}</a></td>
      <td class="series-date">{parents:entry_date format="%M %j, %Y"}</td>
      <td class="series-speaker ">{exp:trunchtml chars="20"}{parents:media-speaker}{/exp:trunchtml}</td>
     </tr>
    {/parents}
    It has the same strangely unsorted look to it.
    You can see in the list at http://upgrade.northlandchurch.net/series/
    The list is effectively unsorted and I can’t get any sort to work. See any dumb mistakes in that code? I’ve tried orderby date, title, entry_date, etc.
  • #5 / May 16, 2013 1:46pm
    Pascal Kriete
    There seems to be a difference between PHP 5.3 and PHP 5.4 in what is considered a valid reference in call_user_func_array(), which is probably why this wasn’t spotted. I still can’t reproduce it locally.
    Could I ask one of you to revert the above change and instead turn line ~576 into:
    $sort_parameters[] =& $columns[$v];
    Note the added ampersand. Thanks!
  • #6 / May 16, 2013 2:46pm
    wondermade
    That returned the error:
    A PHP Error was encountered
    Severity: Warning
    Message: Parameter 2 to array_multisort() expected to be a reference, value given
    Line Number: 583
    The sort doesn’t work there either.
    If it helps, orderby=“random” does work. But no other orderby seems to do anything.
  • #7 / May 16, 2013 3:08pm
    Pascal Kriete
    The second parameter needs to be a reference?! PHP is just playing with me now.
    One more change, if you would be so kind. If that doesn’t do it I’ll spin up a vm with 5.3.3. Keeping my last change, add the same ampersand to the line below. So the two lines would look like this:
    $sort_parameters[] =& constant('SORT_'.strtoupper($sort[$i]));
    Thank you!
  • #8 / May 16, 2013 3:22pm
    wondermade
    No dice:
    Severity: Warning
    Line Number: 584
  • #9 / May 16, 2013 3:28pm
    Pascal Kriete
    Yeah that was my fault:
    $sort_flag = constant('SORT_'.strtoupper($sort[$i]));
    $sort_parameters[] =& $sort_flag;
    And with that - I’m going to find a PHP 5.3 box to tinker on.
  • #10 / May 16, 2013 4:25pm
    wondermade
    That worked! Awesome and thanks! I can now run code like:
    {parents field="media-unit" orderby="date" sort="asc"}
    And the results will sort.
    Thanks for the help!
  • #11 / May 16, 2013 4:31pm
    Pascal Kriete
    Glad to help 😊 .
    Fix will be in the next release so no need to maintain a hack.
  • #12 / Sep 18, 2015 10:24am
    I seem to be running into a similar issue with EE 2.10.1 running on PHP 5.6.11.  I took a quick peak at the code in the relationship parser, but didn’t see a quick fix.  The following is an example of my template.
    {exp:channel:entries channel="clients" limit="1" }
     {parents field="client" orderby="title" sort="asc"}
      <h3><a href="/manager/project/{parents:url_title}">{parents:title}</a> ({title})</h3>
    <p> {/parents}<br />
    And attached is the output.
