CP Content Edit Fail Due to Missing Entry Date?
April 17, 2013 8:17pm
  • #1 / Apr 17, 2013 8:17pm
    Scai Design
    Hi everyone,
    I have a really weird issue when updating an entry through the cp->content->edit.
    Once I hit submit, it stays on the edit page as if a required field was missing. After hours of looking into my own codes, I realized that it was the “entry date” on the Date Tab under edit entry.
    The site has been up and running fine for 6 months. The one major change that I’ve made was to add ee matrix fields into those entries. However, I really don’t think the matrix field could change the entry_date right? Please correct me if i’m wrong.
    I am able to fix it by manually editing the entry date, However that will cause the entry to have an empty status which means it will not show on the front end. Then I would have to manually edit the status again.
    What I did find out was that if I choose a future date for the entry it will not work.
    So I believe the error might be located in the localization setting?
    I am located in Toronto at UTC -5 (EST)
    I have the server Offset to 0 right now. and Daylight saving On.
    Thank you very much for looking into this.
