MSM subsite displaying main site template
April 11, 2013 11:48am
  • #1 / Apr 11, 2013 11:48am
    pieyrot
    I have installed MSM and set up three sites, “live”, “beta” and “internal”.
    Edited the “live” site, created a default template group called “Live” and edited the index template in that group.
    Now I’m editing the “beta” site.  I created a default template group there called “Beta” and edited the index template in that group.
    The problem is: when I go to the URL for the “beta” site, I still get shown the index template for the “live” site!
    How do I debug this problem?
    I feel a bit cheated that I’ve paid for MSM and it does not work correctly.
    I have tried changing uri_protocol to PATH_INFO in the live site’s config.php and it did not fix the problem.
  • #2 / Apr 11, 2013 9:27pm
    KiwiGrrl
    I assume you’re running the beta site from a different url? Have you edited the index.php file and made sure all your paths are correct?
  • #3 / Apr 12, 2013 5:52am
    pieyrot
    It was a much more basic setup problem.  The virtual hosts were not setup correctly in Apache.  This was referenced in the doc, but very vaguely.  Would be good to see at least one example of the configuration for a common setup.
    Thanks for the reply.
