What I'm doing wrong?
April 04, 2013 5:55pm
  • #1 / Apr 04, 2013 5:55pm
    jolupa
    Hi.
    I want different styles depending on the category of the entries and I’m using the following code:
    {exp:channel:entries channel='blog' limit='10' order_by='date' sort='desc'}
       {if '{category}' == '1' OR category == '2'}
        <div class="twelve columns">
         /themes/site_themes/lgnv1/timthumb/timthumb.php?src={imagen_destacada}&h=150&w=1000&zc=1
         <h1><a href="http://{url_title_path=lgnv1/post}">{title}</a></h1>
         {entrada}
        </div>
       {if:else '{category}' == '3'}
         <h1 class="centered">{title}</h1>
         <center>{entrada}</center>
        </div>
    But all that I have is an error rendering the page. Also I try with the following code too:
       {if category == '1' OR category == '2'}
         {entrada}
        </div>
       {if:else category == '3'}
        </div>
    Someone can guide me, please.
    Thanks a lot.
  • #2 / Apr 05, 2013 2:27am
    Riverboy
    Hi, not sure but you use if:else instead of if:elseif, might that be the problem?
    See documents about using those here.
  • #3 / Apr 07, 2013 8:56am
    jolupa
    Well I try the solution you give me but is not working…
    I think I can’t use the category to change the style I want to use, I don’t know.
    Anyone has an idea?
  • #4 / Apr 08, 2013 10:43am
    travisb
    Did you try breaking it down to see if it works in simpler form, for example:
    {exp:channel:entries channel='blog'}
       {if category == "1" OR category == "2"}
        Cat 1 or Cat 2 success
       {if category == '3'}
         Cat 3 success
