Renaming System Directory in 2.5.5
March 24, 2013 12:26pm
  • #1 / Mar 24, 2013 12:26pm
    QuickSilver
    I just completed a fresh install of EE ver. 2.5.5 on my site which is hosted by Network Solutions.
    I have attempted to rename the system directory and make the appropriate entries to the root folder index.php and admin.php files as you described in your post installation document.
    When I try to login to the control panel with http://www.mysite.com/admin.php I get this:
    Your system folder path does not appear to be set correctly. Please open the following file and correct this: admin.php
    If I go to http://www.mysite.com/renamedsystem/
    I get a proper control panel login.
    I have a second index.php in the renamed system directory, do I need to add the system path change to that one as well??
    I have read other posts about file permissions - they are correct.
    I also have a blank config.php file - also a question asked on other posts.
    Seems like a fairly simple thing but I must be missing something.
    Any assistance will be appreciated
  • #2 / Mar 25, 2013 11:51am
    worfoual
    I got this problem to. Clear ur cookies and emty ur cache, it should works.
