Using custom field as primary entry title - any drawbacks?
March 20, 2013 11:04am
  • #1 / Mar 20, 2013 11:04am
    tomjeatt
    I’m working on a project which leans very heavily on Playa and Structure, and is (unavoidably) going to result in a lot of duplicate entry titles. My original plan was to use the title field as the, um, title field and then create a custom field for each channel which could be used for a second, more descriptive title. These could then be pulled into the Edit Channel Entries screen using Zenbu. As Playa only lists content by title, however, this turned out to be a bad idea so I’ve switched the roles around: the title field is now used descriptively but not pulled into any of the templates, whereas each channel has a {[channel_name]_display_title} custom field, which is pulled into the templates.
    Are there any drawbacks to this? I can’t really think of any (Structure will handle custom fields for navigation and page titles) but my approach feels a bit hacky.
  • #2 / Mar 20, 2013 3:48pm
    Rob Allen
    No drawbacks at all, that’s quite a common method. For instance often when I do something like “testimonials”  the Title field is used just as a backend reference but not used in the front end.
  • #3 / Mar 21, 2013 5:22am
    tomjeatt
    Thanks Rob - that’s what I was hoping, so it’s always nice to get a bit of reassurance!
