Sorting by date returning odd results
March 14, 2013 10:52am
  • #1 / Mar 14, 2013 10:52am
    kelseyads2
    I am having an issue sorting by the EE date field. I have a channel “news” that has a few custom fields. I had a custom date field but realized sorting by that was erratic at best, so I deleted it and we edited the EE date field on all the entries.
    Now here’s the weird part, how that I am sorting by the EE date field, it shows about half the entries sorted by date, then starts over with the other half.
    Here is my channel entries tag:
    {exp:channel:entries channel="news" orderby="entry_date" sort="desc" limit="100" show_expired='yes' dynamic="yes" }
    <div class="areaattractions_content">
     <h3><a href="http://{title_permalink=">{title}</a></h3>
    <p> {entry_date format="%F %d %Y"}<br />
     {news_teaser}<br />
    </div><br />
    Note: I have tried “date” and “entry_date” in the exp:channel:entries tag and both produce the exact same results.
    Below is the output of the query above:
    [removed link url after resolved]
    Check out the dates as you scroll… weird!
    Anyone seen this before? Is it a bug? I have completely cleared the EE caches in the last day or two, so that doesn’t appear to be the issue. I’m at a loss as to what I can try.
    Thoughts? Suggestions?
  • #2 / Mar 15, 2013 1:41am
    Bhashkar Yadav
    Hi Brandon,
    Instead of using the parameter orderby=“entry_date” use orderby=“date”. Take a reference from here http://ellislab.com/expressionengine/user-guide/modules/channel/channel_entries.html#orderby
    Best Regards,
  • #3 / Mar 15, 2013 8:23am
    kelseyads2
    Hi Brandon,
    Best Regards,
    Thanks for the suggestion, but as I mentioned above I have tried the EE query using both “date” and “entry_date” and both return the exact same thing.
  • #4 / Mar 15, 2013 8:51am
    Bhashkar Yadav
    Hi Brandon,
    Sorry I didn’t notice your note as mentioned within the first thread.
    Could you check if “Make Entry Sticky” is checked for the entries.
  • #5 / Mar 15, 2013 10:12am
    kelseyads2
    I thought I had checked that before but that was it… they marked a bunch (almost half) of the entries as sticky. Glad to know it’s not a bug, at least. Thanks!
  • #6 / Mar 15, 2013 2:17pm
    Bhashkar Yadav
    Glad to hear it 😊 .
