EE 2.5.5 Using File custom field.
February 15, 2013 10:47pm
Subscribe [0]
  • #1 / Feb 15, 2013 10:47pm
    iPixel
    So, in ee1.x this seemed to work differently via nGen File. Now that ee2.x has it’s own file field, I have come across a question/concern.
    Let’s assume we created a {item_image} custom “file” field.
    When using that field, {item_image} automatically gives you the absolute URL path to the image that was uploaded.
    My issue is that i also used ee’s Image Manipulations to create a _default folder with images sized to a smaller size. But again, using {item_image} points directly to the original file.
    How can I do one of the following.
    1. Stop EE from assuming i want the absolute URL and just give me the image name only.
    2. Tell EE to use that same image but within the _default folder EE itself created.
    btw, _default is no different from ee’s _thumbs just contains slightly larger images.
    Thanks for the help in advance!
  • #2 / Feb 16, 2013 12:33am
    Bhashkar Yadav
    I hope, this example code would answer your both questions:
    {exp:channel:entries channel="CHANNEL_NAME"}
     ITEM IMAGE NAME: {item_image} {filename} {/item_image}
        {item_image}
            {path}_default/{filename}.{extension}
        {/item_image}
    Best Regards,
  • #3 / Feb 16, 2013 12:43am
    iPixel
    Yep, this is EXACTLY what I needed! Thank You Bhashkar!
