using member_id in exp:query
February 07, 2013 7:46am
  • #1 / Feb 07, 2013 7:46am
    77120
    Im trying to get the member_forum_rank on a template outside on the forum with
    {exp:query sql="
         SELECT
         SUM(total_forum_topics+total_forum_posts)
         AS total_forum_posts_for_rank
         FROM exp_members
         WHERE member_id = '<?php global $SESS; echo $SESS->userdata['member_id'];?>' "}
              {exp:query sql="SELECT rank_title FROM exp_forum_ranks WHERE rank_min_posts <= '{total_forum_posts_for_rank}'"}
                   {if count == {total_results}}{rank_title}{/if}
              {/exp:query}
    {/exp:query}
    which work only if i hardcode the member_id, how can i get the {logged_in_member_id} there dynamicly?
    i have php enabled, parse on input and caching is off
    this is the error i get:
    Error Number: 1064
    You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ''
    Filename: modules/query/mod.query.php
    Line Number: 181
    if i only call (leaving the exp:query out)
    i get:
    A PHP Error was encountered
    Severity: Notice
    Message: Trying to get property of non-object
    Filename: libraries/Functions.php(680) : eval()'d code
    Line Number: 50
  • #2 / Mar 05, 2013 4:14am
    77120
    anyone?
  • #3 / Mar 05, 2013 6:21am
    Bhashkar Yadav
    What is the version of your ExpressionEngine install.
  • #4 / Mar 05, 2013 6:32am
    77120
    v2.5.3 - Build Date: 20120911
  • #5 / Mar 05, 2013 6:40am
    Bhashkar Yadav
    As you using EE2.5.3, so {logged_in_member_id} global variable will work.
    {exp:query sql="
         SELECT
         FROM exp_members
         WHERE member_id = '{logged_in_member_id}' "}
              {/exp:query}
    {/exp:query}
  • #6 / Mar 05, 2013 7:33am
    77120
    thanks for your help,
    but {logged_in_member_id} seems to be parsed later then the query :(
  • #7 / Mar 05, 2013 9:44am
    Bhashkar Yadav
    You should have parse parameter with query tag like:
    {exp:query sql="
         SELECT
         FROM exp_members
         WHERE member_id = '{logged_in_member_id}' " parse="inward"}
              {/exp:query}
    {/exp:query}
    Also, can have another solution by using the PHP like:
    $this->EE =& get_instance();
    $member_id = $this->EE->session->userdata['member_id'];
    {exp:query sql="
         SELECT
         FROM exp_members
         WHERE member_id = '<?php echo $member_id; ?>' "}
              {/exp:query}
    {/exp:query}
    If you are using above code example, make sure that template is having preference of “PHP Parsing Stage” as “Input”.
  • #8 / Mar 06, 2013 2:45am
    77120
    ah yes thank you,
    the first code doenst work for me.
    but the second one does which is great 😊  thanks
