Problems with extension Wysiwygpro
February 06, 2013 2:00pm
  • #1 / Feb 06, 2013 2:00pm
    tgEE1
    Hello good afternoon. I have a problem with the extension Wysiwygpro. This happens since I made the change of server.
    Warning: include_once(/usr/home/myname/www/www/SITE/cp/extensions/../../wysiwygPro/wysiwygPro.class.php) [function.include-once]: failed to open stream: No such file or directory in /usr/home/myname/www/www/SITE/cp/extensions/ext.wysiwygproee_communicate.php on line 24
    Warning: include_once() [function.include]: Failed opening ‘/usr/home/myname/www/www/SITE/cp/extensions/../../wysiwygPro/wysiwygPro.class.php’ for inclusion (include_path=’.:/usr/local/lib/php’) in /usr/home/myname/www/www/SITE/cp/extensions/ext.wysiwygproee_communicate.php on line 24
    line 24: include_once(dirname(__FILE__).’/../../wysiwygPro/wysiwygPro.class.php’);
    and
    Warning: include_once(/usr/home/myname/www/www/SITE/cp/extensions/../../wysiwygPro/wysiwygPro.class.php) [function.include-once]: failed to open stream: No such file or directory in /usr/home/myname/www/www/SITE/cp/extensions/ext.wysiwygproee.php on line 52
    Warning: include_once() [function.include]: Failed opening ‘/usr/home/myname/www/www/SITE/cp/extensions/../../wysiwygPro/wysiwygPro.class.php’ for inclusion (include_path=’.:/usr/local/lib/php’) in /usr/home/myname/www/www/SITE/cp/extensions/ext.wysiwygproee.php on line 52
    line 52: include_once(dirname(__FILE__).’/../../wysiwygPro/wysiwygPro.class.php’);
    *++ Url theme cp OK-> /home/myname/www/www/SITE/themes/
    Something similar has happened to someone? Thank you and excuse my bad english
    ExpressionEngine v 1.6.7
  • #2 / Feb 07, 2013 6:30am
    tgEE1
    Has someone installed this extension?
    could you help me please?
  • #3 / Feb 07, 2013 11:49am
    tgEE1
    not compatible with php versions and browsers.
    I have installed ckeditor
  • #4 / Feb 10, 2013 8:04am
    Boyink!
    I can’t seem to dig up anything about WYSIWYGPro - at least as far as it relates to EE.  You are also on an older version of EE that is no longer supported.
    If you need WYSIWYG on EE1 I’d recommend http://pixelandtonic.com/wygwam
