I am trying to set up an image gallery using Matrix and Structure, I can get everything working as it should until I have to paginate the images. I have followed the tutorial on how to paginate matrix on Pixel and Tonic website but this doesn’t work as Structure intercepts the url and just links to an empty page.
I installed Freebie and have set that up to ignore numbers in my urls, this seemed to have worked but now the pagination links just reload and empty page, but the correct page using the correct template. E.g. http://www.mysite.com/nails/gallery is the original url and http://www.mysite.com/nails/gallery/3 is the ‘next’ page of the gallery, but this page doesn’t contain the rest of the images.
Has anyone ever come across this issue before? And if so how did you fix it?
Thanks.
