creating admin panel
January 29, 2013 11:31am
  • #1 / Jan 29, 2013 11:31am
    chaitanya
    I am new to CI and I want to create “Admin” panel for mysite.
    I have created an admin folder inside controller folder and I have login controller inside that(path is application/controller/admin/login.php) .I want to access my admin panel as localhost/mysite/admin
    I am getting
    The requested URL /mysite/admin was not found on this server.. while trying to access admin.
    I would like to know any settings/changes I will have to make in my config or routes file.
    Thanks ,
    Chaitanya
  • #2 / Jan 29, 2013 2:20pm
    Eduard Stankovic
    in your route file add this line
    $route['admin'] = "admin/login";
  • #3 / Jan 30, 2013 4:37am
    chaitanya
    I have tried that still getting the same.
    Any other way to achieve this?
    Chaitanya
  • #4 / Jan 30, 2013 9:48am
    Eduard Stankovic
    what is code of your .htaccess file, route.php and login.php(controller)
  • #5 / Jan 30, 2013 2:00pm
    chaitanya
    I have .htaccess file in root folder.Do I need to add it in my admin folder.
    What changes should I make into my .htacess file.Currently it contains
    Options +FollowSymLinks
    RewriteEngine On
    RewriteBase /
    RewriteRule ^(.*)$ index.php/$1 [L]
    RewriteCond %{THE_REQUEST} ^[^/]*/index\.php [NC]
    RewriteRule ^index\.php(.+) $1 [R=301,L]
    route.php
    $route[‘default_controller’] = “welcome”;
    $route[‘404_override’] = ‘’;
    $route[‘admin’] = “admin/login”;
    login.php
    <?php if ( ! defined(‘BASEPATH’)) exit(‘No direct script access allowed’);
    class Login extends CI_Controller {
    function __construct()
    parent::__construct();
    function index()
    $this->load->helper(array('form'));
    $this->load->view('login_view');
    Thanks.
