Embed Not Working Correctly
January 22, 2013 1:38pm
  • #1 / Jan 22, 2013 1:38pm
    keydin
    I have a weird problem. I just setup a new site and all of the sudden none of my embeds work.
    {embed="global/header"}
    {embed="global/main_nav"}
    {embed="global/footer"}
    None of them are pulling data from their templates.
    Here is the page: http://bibleconsumer.outreachcs.com/
  • #2 / Jan 22, 2013 1:44pm
    keydin
    I noticed it isn’t pulling snippets either.
  • #3 / Jan 22, 2013 4:00pm
    keydin
    Not sure if it is related, but I am trying to add custom fields to a group and it is throwing all of these errors:
    A PHP Error was encountered
    Severity: Warning
    Message: opendir(/home3/techmark/webapps/_system_ee2msm/themes/third_party/mx_google_map/maps-icons/) [function.opendir]: failed to open dir: No such file or directory
    Filename: mx_google_map/ft.mx_google_map.php
    Line Number: 201
    Severity: Warning
    Message: readdir() expects parameter 1 to be resource, boolean given
    Line Number: 203
    Severity: Warning
    Message: closedir() expects parameter 1 to be resource, boolean given
    Line Number: 215
    Severity: Warning
    Message: Cannot modify header information - headers already sent by (output started at /home/techmark/webapps/_system_ee2msm/.system/codeigniter/system/core/Exceptions.php:170)
    Filename: core/Common.php
    Line Number: 405
  • #4 / Jan 22, 2013 4:44pm
    keydin
    I am thinking this may be an issue with the host. 503 errors with sites going up and down, and have multiple sites not loading js or css files. Working with the host to try and resolve problems. Then I can see if EE is the issue.
    It’s been fun thinking out loud and talking to myself on here…. 😊
  • #5 / Jan 23, 2013 9:22am
    keydin
    It’s not the host. I have other sites on the serve that behaving properly, but I am having issues with the sites in this MSM install.
    This all began a few days ago with this site: http://lisawhelchel.com. On the front page, all of the sudden the js for a image rotator stop working. You can see in the code that the images are there, but are hidden and then the js is supposed to display them. Then you will see on http://www.lisawhelchel.com/photos/headshots that the javascript for the popup on the pictures isn’t firing.
    I started creating this new site in the last couple of days http://consumerbible.outreachcs.com. I am using embeds that for the header, nav, and footer that are just being ignored, so no css, js, or anything is showing up. I even tried manually sticking in the css and it won’t pull in any of the style there either.
    Also, when I try to add custom fields to a custom group, most of the time it will throw a bunch of php error very quickly (I can’t read what they are) and then shoot me back to a login screen.
    I am not sure what is going on, but I need to figure this out ASAP, so can someone please give me a hand?
    BTW: When did EllisLab start charging for support? Licenses are expensive enough, sheesh. I could really use their help now.
