Okay, I give up! I’m trying to get an entry_id to a playa tag, but the parsing must be off. I’ve tried every combination I can think of - is it something obvious?
This….
{exp:stash:get name='member_client_id' scope='user'}Is calling this…
{exp:stash:set name="member_client_id" parse_tags="yes" parse_depth="2"}
{exp:vmg_chosen_member:assoc_entries field="clientMembers" member_id="{member_id}"}
{exp:channel:entries require_entry="yes" channel="client" entry_id="{cm_entry_ids}"}
{entry_id}
{/exp:vmg_chosen_member:assoc_entries}
{/exp:stash:set}Which I’m using as a Playa parameter…
{exp:playa:parents channel="email" field="emailClient" entry_id="{exp:stash:get name='member_client_id' scope='user'}" parse="inward"}
{title}
{/exp:playa:parents}...which returns nothing.
I’ve tried embedding it in a stash temple too… not luck:
{stash:embed name="client_id" parse_tags="yes" parse_depth="2" scope="user" replace="yes" output="no" process="start" save="yes" parse_stage="set"}What am I doing wrong?
