Here is my code:
<div class="page-header">
<h1>Category: <small>{segment_2_category_name}</small></h1>
</div>
<div id="feed" class="mosaic" data-cat-id="{segment_2_category_id}" data-cat="{segment_2}">
{exp:channel:entries channel="items" limit="30" paginate_base="explore/{segment_2}/p" category="{segment_2_category_id}"}
{exp:ce_cache:it id="feed_item_{entry_id}" global="yes" tags="item|feed"}{embed="site_inc/_feed_check" theentryid="{entry_id}" itemname="{url_title}" itemuser="{username}" itemuserid="{author_id}" gridsize="span3"}{/exp:ce_cache:it}
{paginate}
{exp:string:set name="pagination_cat"}
<nav id="feed-pager">
{if next_page}<a href="http://{auto_path}%22id=%22next" class="next js_hide_next">Next Page</a>{/if}</nav>
{/exp:string:set}
{/paginate}
</div>This code works on every category on my site except for one. I can’t seem to figure out why it is breaking for this one particular category but if anyone has any ideas, I’m all ears! Even on the page with the category that doesn’t work, I get the proper information displayed outside the loop (category title & id), but the loop seems to be broken.
