checkbox won't set
December 05, 2012 6:00pm
  • #1 / Dec 05, 2012 6:00pm
    fiunary
    I have a simple checkbox custom field (several actually).  I go to edit record, set the checkbox and submit ... but when I check the record the checkbox has not set.  Something silly I am sure.  Thanks for your help.  Alex
  • #2 / Dec 05, 2012 7:31pm
    fiunary
    It seems that checkboxes work as lists.  I simply want a boolean checkbox in my record that I set when I publish or edit a record in the CP.  Checked is true.  Unchecked is false.  Is this not simple?  Do I have to put true and false labels and select accordingly?
  • #3 / Dec 05, 2012 11:51pm
    Bhashkar Yadav
    Hi Alex,
    Are you using Safecraker entry form? If so use the parameter preserve_checkboxes=“yes”.
    Best Regards,
