Removing index.php issues
November 13, 2012 8:50am
  • #1 / Nov 13, 2012 8:50am
    Lisa E
    Hello—
    I followed the steps on removing index.php. I’ve had no problems doing this in the past, but I’m on a server that is not hosted by a provider that I am familiar with and I’m having some issues.
    I followed both methods of the ReWrite Rule (forced and unforced query strings), but when I remove index.php I still get a 404.
    Any ideas of anything else that could be causing this issue? I’m not on a sub-domain.
    Sincerely,
    Stumped!
    Lisa
  • #2 / Nov 13, 2012 8:56am
    glenndavisgroup
    Hi Lisa,
    Which version of EE are you using?
    Can you post your entire htaccess content here so we can have a look?
    Thank you,
    Mike
  • #3 / Nov 13, 2012 9:06am
    Lisa E
    EE 2.5.2
    <IfModule mod_rewrite.c>
            RewriteEngine On
            # Removes index.php from ExpressionEngine URLs
    </IfModule>
  • #4 / Nov 13, 2012 9:11am
    glenndavisgroup
    Hi Lisa,
    Try changing the last rewrite rule to the following:
    RewriteRule ^(.*)$ /index.php?$1 [L]
    Let me know if that works.
    Thank you,
    Mike
  • #5 / Nov 13, 2012 9:22am
    Lisa E
    Did not work.
    The interesting thing is I can leave the htaccess file edited and up and if i put index.php back into EE, it doesn’t seem to effect at all.
  • #6 / Nov 13, 2012 9:38am
    glenndavisgroup
    Does the site work if you don’t remove index.php?
    Mike
  • #7 / Nov 13, 2012 10:04am
    Lisa E
    yep
  • #8 / Nov 13, 2012 1:52pm
    glenndavisgroup
    Did you by any chance remove the index.php from “Admin > General Configuration > Name of your site’s index page”? You should also clear your EE cache just to make sure there is nothing being cached.
  • #9 / Nov 13, 2012 2:05pm
    Lisa E
    Yes…no luck :(
  • #10 / Nov 13, 2012 2:27pm
    glenndavisgroup
    The only other thing I can think of is your htaccess is disabled. Can you check with your hosting company to make sure that you can use htaccess files?
    Mike
  • #11 / Nov 13, 2012 6:14pm
    Lisa E
    That was the issue. ALl good now. Thanks for the help, Mike!
  • #12 / Nov 14, 2012 11:03am
    glenndavisgroup
    No problem. I’m glad you got it sorted out :D
    Mike
  • #13 / Nov 15, 2012 11:04am
    Dan Decker
    Hi Lisa!
    Nice to see that you and Mike were able to sort it out!
    If we can do anything else, please let us know.
