I have a radio button fieldtype with the values 0 - 10. It outputs fine in my Safecracker form with the {field:my_field_name} tag. However when I try to use the {options:my_field_name} tag pair to customise the markup, the zero value is removed from the radio button group. It doesn’t matter what order the values are presented when setting up the fieldtype, the zero value is always removed. Here’s the code I’m trying to use:
<label><input name="{option_name}" value="{option_value}" type="radio"{checked}> {option_value}</label>
{/options:my_field_name}Thanks,
Dylan
