Condition confusion
November 09, 2012 11:59am
  • #1 / Nov 09, 2012 11:59am
    Jason Turcotte
    I’m trying to create a template that will determine what content to show based on a conditional that evaluates segment_2.
    <!-- determine county -->
        {if "{segment_2}" == "belknap-county"}
        <!-- belknap county -->
        {exp:channel:entries channel="belknap_county_listings" dynamic="no"}
        {if:elseif "{segment_2}" == "carroll-county"}
        <!-- carroll county -->
        {exp:channel:entries channel="carroll_county_listings" dynamic="no"}
        {if:elseif "{segment_2}" == "cheshire-county"}
        <!-- cheshire county -->
        {exp:channel:entries channel="cheshire_county_listings" dynamic="no"}
        {if:elseif "{segment_2}" == "coos-county"}
        <!-- coos county -->
        {exp:channel:entries channel="coos_county_listings" dynamic="no"}
        {if:elseif "{segment_2}" == "grafton-county"}
        <!-- grafton county -->
        {exp:channel:entries channel="grafton_county_listings" dynamic="no"}
        {if:elseif "{segment_2}" == "hillsborough-county"}
        <!-- hillsborough county -->
        {exp:channel:entries channel="hillsborough_county_listings" dynamic="no"}
        {if:elseif "{segment_2}" == "merrimack-county"}
        <!-- merrimack county -->
        {exp:channel:entries channel="merrimack_county_listings" dynamic="no"}
        {if:elseif "{segment_2}" == "rockingham-county"}
        <!-- rockingham county -->
        {exp:channel:entries channel="rockingham_county_listings" dynamic="no"}
        {if:elseif "{segment_2}" == "stafford-county"}
        <!-- stafford county -->
        {exp:channel:entries channel="stafford_county_listings" dynamic="no"}
        {if:elseif "{segment_2}" == "sullivan-county"}
        <!-- sullivan county -->
        {exp:channel:entries channel="sullivan_county_listings" dynamic="no"}
        {if:else}
        <h2>Not sure what county you are looking for…</h2>
    <p>    {/if}<br />
        </p><h2>{title}</h2>
    <p>    {cty_page_content}<br />
    The conditional appears to be working properly because I can see the comments in the code that indicate which branch of the statement was evaluated. The (very) confusing part is that no matter what branch evaluates as true, I get channel entries for the first channel only (meaning the “belknap_county_listings” channel).
    I’ve turned on template debugging and see the following, no matter what:
    (0.011003 / 11.74MB) Tag: {exp:channel:entries channel="belknap_county_listings" dynamic="no"}
    (0.011058 / 11.74MB) Closing Tag Found
    Any thoughts on why this would be happening? Can you not use the opening channels tag in a conditional statement? My thoughts are that it’s parsing the tag, regardless of the conditional.
  • #2 / Nov 11, 2012 10:30am
    Boyink!
    Historically the logic has been that you can’t split up the channel:entries tag like that - the entire loop has be to within the conditional node.  Have you tested that?
    Alternatively, were it me I’d go back and rename my channels slightly so that I could just do:
    {exp:channel:entries channel="[segment_2}_listings" dynamic="no"}
    And avoid the conditionals altogether.
  • #3 / Nov 12, 2012 11:00am
    Shane Eckert
    Hey there Jason,
    What do you think of Mike’s input? Sounds fantastic to me!
    Please let us know where things are at.
